right i got EVGA 8800GTS KO ACS3 the other week, and supreme commander for some reason refuses to play, it did, then it didn't, it gets past intro, to menu screen then crashes randomly, i couldn't use the normal 6-pin PCI-E connector socket i have on my PSU cause theres a bloody big case fan in the way, so i used the molex > 6-pin that came with the card, is this fine to use or should i be using the 6-pin on my PSU, or is there another problem im not seeing?
