Possible Issues with i5 2500K Stock Cooler
4 Jan 2010
Hey,
I think this is the most appropriate forum for my question, even though I am not overclocking I am having some issues with a new system I've built.
I recently build a system
i5 2500K 1156 (Stock Cooler)
Asus P8P67 Pro
Nvidia 460 GTX
8 GB DDR RAM
Corsair 750 Watt TX
ANTEC One Hundred case (have not installed any additional fans at the front or on the side panel yet)
At the moment I am not overclocking or have any intentions at this time, I just want the system to run.
The only issues I am having is when I am playing Crysis 2 after about 10 minutes I get a loud beep, the sound is still playing but my system hardlocks and what I have left on my screen I can only describe as Spectrum 48k rainbow graphics.
When I restarted the computer I had a BIOS warning about the CPU temperature been too high.
Overall I've had no other issues, system seems very stable, no other crashes, I've ran SC2, WOW and the Witcher so far and had no issues with those games but in my experience that doesn't mean their isn't something amiss.
I am using the stock cooler for now (i'll likely get a third-party when I next get paid) but the stock cooler should be enough, more so when I am not overclocking, the cooler is seated properly and has the clips through the board okay the screws are tight.
If I check the temps in the BIOS from a cold boot, its quickly pushes up towards 84c, yet if I check in Windows its show on average 45 (Speedfan, CPUID)
What I am worried about is the CPU frying, has anyone else had issues with the stock i5 2500k cooler?
I don't think its an issue with my graphic card, at least not yet annyway, since the BIOS warning.
I've not changed any BIOS settings and from what I am see, everything is on stock standard speeds.
Yeah, took that off, checked there was nothing on the thermal plate on the CPU, and the cooler had some thermal paste I Can only describe as looking like this ] | [, which is strange, but I've not build a computer since I had an AMD X2 so I guess this how Intel designs their coolers and paste.
The only fans the standard Antec coolers at the upper back and top of the Case. I am planning on getting some 3 more fans, 2 for the front and 1 for the side.
Any chance that one of the push pins on the stock cooler did not quite "lock home"?
Did you look at the back of the mobo after installing the cooler to check that the push pins had locked correctly? (see handy guide that should have come with your CPU).
If it was me, I would just remove the HSF, clean up with TIM remover, add new paste and re-fit.
I this very thing last night and indeed it seems that two of hte pins where indeed not exactly plush, pretty sure they where but everything seems seated and the temps seemed to have levelled off now 33C on idle pushes to about 50c on load.
So thats fixed one potential and thankfully no obvious lasting effects, but Crysis 2 still crashes :|, thanks for the help all.
