Hi All
I have a rather frustrating problem with my new rig, I’m getting numerous BSODs. The prominent one is page_fault_in_nonpaged_area, I have also gotten system_service_exception and memory_management.
I’m running an i7 920, OCZ Reaper PC3-15000, Gainward GeForce GTX275, X-Fi Fatal1ty Pro on an Asus P6T, powered by a Be Quiet! 650W.
I set up this rig about 2 months ago, and everything ran beautifully. I started out using windows 7 RC build 7201 x64. this worked fine for about 2months. But about 2 weeks ago I suddenly started to get BSODs. The cheeky little buggers would sneak in when I went to the loo and I’d return to the windows log in screen.
After a good googling, I came to the conclusion it could be one of a few things, 1)memory problems, 2)corrupt drives / hard disk, 3) motherboard problems. I ran the windows memory test, which brought back errors, so then I ran Memtest 3.4, 3.5 just doesn’t work, for a number of passes and the memory came back clean. This was mighty odd, I know windows memory test is a bit shody, but didn’t think it would detect errors that memtest doesn’t. so then I ran the windows memory test again, that cam back clean. So I decided to replace my hard drive, it needed doing any way and this gave me a good excuse, so now I have 2x 320gb Samsung Spinpoints in RAID0. I reinstalled windows, now using win7 RTM x64, and again everything seemed to work fine, for about a day. Then the BSODs returned.
So, I’ve pretty much ruled out hard drive / corrupt drives, and I thought I’d ruled out memory problems. So I then updated my bios to the latest version to see if that would work. Alas no joy, and instead of blue screening straight aways sometime things just start crashing, the windows transparent themes dies, then explorer, then other programs like photoshop and visual studio, just crash then I get my blue screen. So I decided to run mem test again, and now I’m getting some errors.
Before I RMA my memory, does anyone have any experience with any similar problem, could this be my motherboard playing up as well as, on instead of my memory. As on occation during my crashes, the system would boot up showing 4gb memory instead of 6. this I assumed at the time to be a memory problem with 1 stick just dying, but I’m not sure, haven’t had that same glitch for a few days.
Thanks in advance
Thanks in advance
