Possible new build - a couple of questions
9 Jul 2003
Hi all, I am thinking of upgrading to the following and wanted to check that my current psu would be good enough to run it! It is the one which comes with the antec sonata 3 case and in addition to the below there would also be another 500Gb hard-drive and a dvd drive / blu-ray drive depending on the psu situation :D
Any comments/suggestions on alternative parts would also be welcome although this is about the maximum I would want to spend :)
I take it you were planning on overclocking this? In theory, if the 500w PSU puts out what it claims (or near it) you should be OK.
That would do fine for now, just bear in mind you'll probably need a new psu in the not too distant future, especially if you upgrade again.
