Hi,
Ive been out of the loop in terms of latest hardware for years. My current system is a Q6600 overclocked to 3.4ghz and its done me well for many years. But I think I fancy an upgrade.
I have the GPU (an ATI 6870) which I think is sufficient enough to put in the new build - any advice what cpu, mobo, ram and power supply I would need?
I like to overclock and get the most value for money, budget is probably around 500 quid. Main use will be gaming.
Thanks guys, just have no idea what is currently the best bang for buck or where to start!
You don't need hyperthreading for gaming since most games just don't use it. An overclocked i5 will run all games well, and is better value for money than the i7 too.
