- 16 Mar 2011
Hi guys
Playing around with my new build (GA-P67A-UD4-B3 + i5 2500k) and have run into an issue.
Got it running happily last night at 4.5ghz - and set up 2 BIOS profiles, [email protected] and [email protected] (which I'd be using most of the time).
This morning, I put it to sleep and it wouldn't wake up - so I went into the BIOS (@3.3) - to make sure I had enabled the 'wake with mouse/keyboard). Did it, saved the BIOS and rebooted.
This is where the issue has started. It won't reboot. Power comes on, CPU fan spins then slows, no output from VGA... then it switches off - for about 5 seconds then powers up again. This cycle is just repeated...
I've cleared the CMOS jumper but to no avail. Currently got the battery out leaving it for a while.
I'm using an ANtec 300 case and there is no speaker - so getting no POST errors.
Any ideas?
Thanks
Si
Any ideas?
Thanks
Si
