Hi all,
Got a problem with my computer and hopefully someone will be able to help me out here. First off here is my build:
Intel 2600k @ stock speeds
MSI P67A-GD65
Corsair XMS3 8GB RAM (2x4GB)
Ati 5850 1GB
2x Spinpoint F1 1TB HDD
1x Seagate 2TB HDD
1x Sony DVD RW (SATA)
Windows 7 Home Premium 64bit
So here is the problem:
Last night I was just browsing the internet (had a few other programs like Steam, Mumble, iTunes etc running in the background, nothing too taxing. Then suddenly chrome froze and my pc started running really slowly. I waited a min and it came back and was fine for another minute then my whole PC started running slowly. Explorer kept crashing and it was pretty much unusable.
I decided to restart. It posted fine and got to the windows loading screen, The glowing window never appeared and the pc hung here. Another restart, got to the windows loading screen, the glowing window appeared but the pc just stayed here again.
Another restart then it started having problems even getting to the motherboards logo showing up. It does it's ram checks etc then before the mobo logo appears a flashing "_" appears at the top left of the screen and numbers/letters show up at the bottom right.
First off there are numbers like "99" "98" etc... these go by pretty fast so are hard to make out. Then "A3" appears and stays on the screen for a varied amount of time (anything from 5 secs to 1 min). Then "A2" appears at the bottom left and it will stay there for anything from 30 seconds to 2 or 3 minutes.
"A2" disappears and then the motherboards logo shows up and disappears. Then another "_" appears at the top left and nothing happens.
Now I've tried taking out all SATA devices and the boot process happens as it should, very quickly, no "99" or A2 or A3 or anything. Obviously widows wont load since there are no hard drives present.
If I have the hard drives plugged in sometimes they show up in the BIOS, sometimes only one or two show up. The DVD drive never shows up.
So I'm guessing there is something wrong with my motherboard. It doesn't have the latest BIOS version installed since I've not had a problem since I built the PC 2 months or so ago.
Does anyone have any ideas what has caused this and how I can fix it?
If you need to know anything else please let me know and I'll get the what you need on here asap.
Sorry for the large post, just wanted to give you all the info I can.
Thanks for any help, greatly appreciated!
Cheers.
MSI P67A-GD65
Ati 5850 1GB
1x Seagate 2TB HDD
Cheers.
(sorry for double post)
