- 16 Mar 2006
- Telford
Hello,
I've just built a new gaming PC, all working beautifully apart from one issue:
I went for a X1900 XT Crossfire setup thanks to the special offers on here this week
Installed the Catalyst 6.3 drivers and the 0311 BIOS for the A8R32-MVP, but I have problems with the PC shutting down when Crossfire is enabled and I try playing games. Managed to play HL2 for a few minutes but the PC just shutdown when loading the next section, WoW doesn't get past the initial menu screen. Everything works 100% when I disable Crossfire and just use the one GPU - I'm thinking this is probably a PSU problem as I've only got a 550W one at the moment, placed an order for a 650W anyway but I just wanted second opinions - is there anything else that could cause this that I might have overlooked?
Cheers
Installed the Catalyst 6.3 drivers and the 0311 BIOS for the A8R32-MVP, but I have problems with the PC shutting down when Crossfire is enabled and I try playing games. Managed to play HL2 for a few minutes but the PC just shutdown when loading the next section, WoW doesn't get past the initial menu screen. Everything works 100% when I disable Crossfire and just use the one GPU - I'm thinking this is probably a PSU problem as I've only got a 550W one at the moment, placed an order for a 650W anyway but I just wanted second opinions - is there anything else that could cause this that I might have overlooked?Cheers
Thought I'd blown something in a really bad way
