Possible stupid question.
10 Mar 2015
So i am looking at GPU and there is different models all with different about of RAM attached with various OC and x thrown about on the end of them.
For it seems the higher the model with more RAM seems to be the best but i'm sure i am wrong on this most likely.
Bottom line what should i look for in a GPU if i want a fairly decent one, is there any particular stat which is the best stat to look at or is it a number of factors?
Thanks.
Possibly also depends what resolution you want to play at.
I have MSI's 780 Lightning, which is plenty good - Overclocks pretty well if you're into that and even at stock speeds has no problem with any game out there. However, I'm still only playing in 1080p.
If you're looking at 1440 or above, you'll more likely want the likes of a 780Ti, an R9 290X or perhaps the new 980.
Its not always about how much memory its also the bus that connects them. What's your budget as that will allow people to recommend whats best
Theres a few questions you need to ask yourself...
1. What games do you wanna play and what level of settings are you happy playing at?
2. What resolution is your monitor?
3. Whats your budget?
4. What spec is your system and Wattage of PSU and is there likely to be any older /slower components that will bottleneck your new Graphics card?
I'll agree with them :)
1. Most intensive is PS2 then EVE online and maybe Warframe, every other games like Total War Rome and XCOM:EW and ETS2 are not that heavy i would say.
2. 1600 x 900
3/4. Looking at this particular build.
YOUR BASKET
1 x Gigabyte Z97X-SLI - Devils Canyon Core i5 4690K Bundle **£12 Saving** £277.98
1 x MSI Radeon R9 280 Gaming 3072MB GDDR5 PCI-Express Graphics Card £149.99
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02733) £84.95
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £51.95
1 x Kingston 120GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/120G) £49.99
1 x Kingston HyperX Savage Red 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/8) £46.99
1 x BitFenix Outlaw Gaming Case 3.0 USB - White £44.99
1 x Seagate Barracuda 1TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £42.95
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £19.99
1 x Raijintek Aidos Direct Contact CPU Cooler £14.99
Total : £801.26 (includes shipping : £13.75).
