possible to disable adblock+ for certain youtubers?
15 Feb 2011
Slough
As much as i like Adblock+ I feel kinda bad that my view will mean sod all to my favourite youtubers (instead of very nearly sod all) because of adblock+, so if anyone can either find a way of disabling adblock+ for certain youtubers, or find some other adblock software that can do what I want (so that i can disable adblock+ for youtube) that would be great.
you can disable it on a per site/per page basis. if you can't see it, enable your addon bar or stick it on another toolbar.
this assumes you're using firefox. i don't know about other versions.
i know i can do it per site and per page, but i really cant be stuffed to unblock every youtube video from the subs who i like enough to watch adverts for, and i dont want to unblock the whole of youtube because the adverts are incredibly annoying.
guess i'll just have to feel kinda bad at not giving my favourite youtubers 0.001p for my view, or whatever amount it is
how would you expect it to work? you can't tell who the uploader is from the URL. the only thing that makes one page from another is the v=BLAH bit.
i'd toggle it on/off for the whole site when watching their vids. that would be easier and cleaner than adding filters for every page.
