Hi All,
Would it be possible to get a better spec than a 6300 @ 2.8ghz & 4gb ram for the above budget? (Ideally £100 - £150)
Basically in need of a new motherboard as the memory slots are playing up so only running single channel and a clock of only 2.8ghz instead of the 3.2ghz i used to be able to get.
PC mainly for gaming.
Current gfx card is 4850.
Thanks
Thanks
