Possible to get any touchscreen to work on a PC?
27 Apr 2013
UK, Manchester
Alright guys, So I have been toying with the idea of building a carputer, I already have the hardware.
No this might sound a little crazy but bear with me.
My In car radio has a small 3.5" touchscreen and an AUX input.
Would there be ay way i could use the touchscreens digitizer and input that into the PC at all?
Is it built into the car or third party? What OS are you planning on running?
If its third party there is a chance you could re-purpose it depending on how off the shelf it is, but its unlikely it'll be particularly plug and play.
