Possible to remove a file within regedit ?
10 Jan 2006
Bournemouth tbh
Does anyone know the path within regedit to My Documents?
I have this file in My Docs which I cannot delete and was looking to hop to the relevant file within regedit and get rid of it there?
Anyone ?
What type of file is it? If it's being used by windows then there is a probably a good reason for it.
My documents isn't in the registry though is it...it's a folder.
But the path to it, if you were pointing to it in the registry would be
"C:\Documents and Settings\*username*\My Documents"
That said...I'd be tempted to agree with marc2003's first comment... ;)
The only way I think that regedit could help, would be to create a batch file to remove the file, and add the path to the batch file in the runonce path of the registry.
Not really a solution, but it is the only way I could think that the registry could be of any use what so ever.
Boot into DOS, delete the file, reboot.
Job done.
