I have a two files in C:\Windows.. they are update.exe and update1.exe.
Ive been trying to work out what virus/adaware it is... NOD32 (supposed to be best antivirus on the planet) finds nothing!
I am going to give you a download link to the file but DO NOT OPEN OR RUN THE .EXE INSIDE!!!!!! but you can extract it and use it to help me find out what it is.
Here is the link: http://www.richieward.com/junk/update.zip
Put the file through your anti-virus and spyware applications for me
Submit it to your anti-virus vendor if you wish.
