Possible upgrade needed, been a bit heavy handed...
17 Jan 2007
London
Managed to snap the retention clip off the PCI Express slot with my 6970 last night whilst trying to get to the SATA ports to install a new SSD, now the display wont work....
At first it started screeching, which turned out to be a knocked out power cable (one of them is power socket -> 2x molex, which are extensions/daisy chains from other devices - should I be concerned about this??)
Now everything is plugged back in, I get just a black screen and no screeching. For now Im using on-board VGA, so at least the mobo and everything else looks fine...
Im going to try connecting the GPU directly to the PSU with dedicated cables later to see if that works, then might try the next PCI Express slot, but if all else fails, is a 7970 generally considered the best upgrade, bang for buck wise?
I play mostly BF3 these days, with maybe a bit of Tomb Raider/Alan Wake/GTA 4
Think Im more leaning towards the 670, purely because it seems to perform better in BF3 and I have all but 1 of the games in the bundle, not really bothered about Crysis 3 tbh
Im just praying I dont have to buy anything, really could do without spending more cash :S
OK - have tried card in 2nd slot, tried cabling it direct to the PSU and verified in BIOS that no overclocking options are enabled and primary GFX is PCI-Express....
New graphics card time?? Or anything else I can try??
Well that's just madness.....
Gave it one last go with just DVI connected in 2nd slot and bingo! Now moved back to original slot with both DVI and HDMI connected, just played a round of BF3...
Well, I aint complaining, must have pleased the hardware Gods today
