- 31 Oct 2012
- Edinburgh
Hi all,
I've got an old desktop that I'm considering refreshing with a new graphics card. Not looking to make it actually decent or anything, just better. However, a power surge pried my old PSU a while back and when I replaced it I was feeling like I wouldn't upgrade so was pretty conservative. I'm wondering if I can make improvements without replacing the PSU too.
Pre-upgrade:
CPU: i5 750 @ 3.2 (Can go much higher but this is my 'normal', stock volts clocks) w. Arctic Freezer 7 rev 2
Mobo: Asus p7p55d-le
Ram: 4GB Corsair 1600MHz C8 (2*2GB)
GPU: Sapphire HD 5750 w. Arctic Acelero Mono Plus VGA cooler
PSU: Corsair Builder Series CX 430W V2 '80 Plus Bronze' Power Supply
HDD: Single spinny-platter of some variety
Other bits: TV card of some type, DVD drive
What I am thinking of getting:
HIS 7850
A quick glance suggests this is a 46W increase in max draw but I've no idea what I'm drawing now so not sure if I can do this or not. It is probably a smaller increase as my current graphics card is overclocked (can't remember off the top of my head how much, I'd need to check and am at work just now) but then one of the advantages of the linked card is apparently its overclockability.
Would this work? Be feasible? Give a noticable improvement?
etc etc.
Pre-upgrade:
HIS 7850
etc etc.
But it will tell you the power draw at the other end of the PSU, so you have to factor in the loss of efficiency as well (record 300W at the plug, 80% estimated efficiency, components draw 240W). But if you run into those margins, your PSU is already well stressed.
