Possible Upgrades
29 Mar 2005
Been out of the loop in regards to the latest hardware and I would appreciate any advice of what to upgrade. The specs can be found in my sig.
Probably the graphics card and ram, not looking to spend too much money but at the same time not get anything that won’t last for awhile. I am also looking at getting 2 GB of ram.
I mainly use the computer to play games, but not the latest titles.
Thanks
*edit* Removed the budget
Probably the graphics card and ram, not looking to spend too much money but at the same time not get anything that won’t last for awhile. Looking at a £200 budget, but willing to go higher. I am also looking at getting 2 GB of ram.
Thanks
ok... Yes 2Gb of RAM is worth it... but you wouldnt get much change out of £200
Stelly
Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-044-CO)
£160.92 inc VAT
It's never been that cheap before, what a bargain. When these first came out, they sold for £234 inc VAT.
£160.92 inc VAT
Cool, did a quick Google search for benchmarks and didn’t find much, would there be much improvement over the 6600GT that I currently have that warrants spending ~£160 on it?
Also in the past I heard that the DFI boards are picky on the ram, is this true and if it is what brands are worth avoiding or worth using.
Thanks for all the replies so far.
