possible xbox 360 sound setup madness for me?
21 Jan 2006
Right guys,
I'm about to go and get my core unit in 2 hours, but I have a question about sound and speakers for it... a little late in the day to worry, but here we go...
I have a TFT and the VGA cable so I can play in HD, but my TFT doesn't have in-built speakers. I have an adapter for the red and white sound leads to make it 1 lead which can then be plugged into whatever...
I have PC speakers with 2 front connections...
1 with a pic of what looks like a microphone next to it and 1 with a headphones icon next to it.
At the back there are no further connections.
Do you guys reckon the 360 will work with the PC speakers if I plug into one of those connections on the front?
Or will my 360 have no sound until i buy some new speakers?
:confused: :(
i think the microphone socket on your speakers should work.
but the way i did it was to run the sound output from the xbox 360 into the line in on my pc sound card. the only problem with this is that i have to have the pc on for it to work.
I was thinking i'd need to do that. I'll try both obviously when I get it. My PC is always on anyway :)
Thanks
