Hi everyone.
Yesterday i installed the Zalman tritium cpu cooler onto my motherboard, and plugged the 4-pin switch into the 4-pin socked labeled cpu fan on my motherboard.
I wanted to test it out, 1 to see if the fan worked, and 2, to look at the nice green light
Anyway, i turned on my machine (please bare in mind that i dont yet have a graphics card, or hard drive plugged into the mobo)
The green LED was fine, but the fan didn't spin, it looked like it wasned to spin, as there was slight movement, but it wouldnt start spinning until i span it with my finger.
Is this a problem with my mobo or the cooler itsself? or is it to do with the settings i have to change in the bios, which causes the fan to speed up when the temps are higher.
Thanks!
Thanks!
