Possibly caught by a traffic light camera
12 Aug 2010
London
May have been caught by one of those grey traffic light cameras which are seemingly on every set of lights in london. Thanks to a lapse in concentration I ended up going through the lights around two seconds after they had turned red. Pedestrians hadn't begun to cross or anything, but still it obviously was a stupid mistake on my part. I don't think I was speeding (in fact, I think I was doing under the limit) but if I was speeding, I would have been no more than 5MPH over.
Anyway, I can't say I noticed a flash of any kind, although it was a clear day so do they flash? I was in the outside lane as well, and have heard some reports that they only measure the inside lane, which seems hard to believe.
So, based on what I've said, is it likely that I was caught? If so, what would the penalty be and if I don't get anything after 14 days will I be in the clear?
Thanks, and inb4 child killer, rot in hell etc etc :rolleyes:
It depends on the type of camera, some have flashes, some don't.
Consider this, I often pass a traffic light in London in my HGV on green, but due to the snails pace of the traffic its not uncommon for my 45ft trailer to pass the camera a few seconds after the light has actually changed to red.
I've yet to recieve a ticket / nip for this and would imagine you may be in the clear. (Famous last words eh?)
Either way, rot in Hell you child killer! :mad::p:D
Good point - I've never thought about it that way. I looked them up on google and of course got hundreds of daily mail-esque articles telling me how many thousands of people are caught each year, which was mainly what worried me; I'd always thought they were for the occasional nutter that goes through them at 150MPH at night.
Thanks for the info anyway, I'm just off outside to clean all the blood off my bonnet :p
I had this exact same feeling couple of months back, but i never saw a flash (Most of them do flash i believe) and ended up in the clear.
Oh, and these cameras will only peanalise you if you start to go through on red, so in a HGV you'd be fine. (Spent a while researching while worrying)
Fingers crossed you get away with it
You've got the usual 14 days + postage, which is 1 working day I believe, then you're in the clear. It's the usual 3 points & £60 if you do get caught though.
I wish they could detect those morons who creep over the line while it's still red. Worse still, half the time they don't even pull away particularly quickly.
That's a good and bad idea, some people so etimes only just end up braking past the line, but accidentally, plus you're not as such doi g anything massively wrong?
So you enter a junction when your exit isn't clear enough for you to go into it?
In certain situations, given as I say this is London,but, by no means as a matter of routine,sometimes, yes. :o - as I'm sure you do!
That's completely fine to do if there isn't a yellow box, especially in heavy traffic (obviously it's not nice to deliberately block the junction).
It was fairly tongue in cheek after getting particularly annoyed with someone blocking a junction for 3 changes of lights last night.
I had actually thought that the rule applied to all junctions, but apparently it only does in the EU excluding the UK.
Find a picture of a camera... Most of the CCTV-like structures are just sensors.
No, it was definitely a camera, one of these to be precise:
According to a colleague they're 'active' up to 5 seconds after the lights turn red. Anything going through on a red after that point won't get snapped.
As above, you just gotta hope it wasn't operational. :(
My understanding was the opposite, that if you just get through as it turns you'll be ok, it's for people genuinely running the light
If you brake and come to an actual stop just over the line, then fine. It's the people who don't come to a complete stop at all - or start creeping forward ages before the light even goes amber - that annoy me immensely.
