- 15 Feb 2010
I left my PC on last night for the first time; did Avast scan and it found three infected files; all "Win32:Cybot-KI [Trj]" in file names:
"C\windows\SysWOW64\Kernal32.dll [Emul]"
"C\windows\winsxs...[Emul]"
I accidentally clicked move to chest; two of them went in there the other did not; it said cannot find file.Avst said you should do a boot scan to complete the operation; or something tot hat effect. I restarted to do full scans but then windows did not load properly. I am very concerned that someone hacked into my PC and left this backdoor or whatever on my PC (i did lock my PC with a password over night).
The only icons in the system tray are sound and network; no Avast or firewall icons. My mouse short cuts did not work apart from to documents disk. I cannot open action center or network and sharing. After a while action center says do you want to turn on avast, firewall etc i click yes i trust publisher but nothing happens. The avast service is "stopped" in task manager; and when i try to manually start it says "the operation could not be completed... the service did not respond to the start or control request in a timely fashion". The only non-Microsoft service running is nvida.
I recently install comado dragon browser when i try to uninstall any program it says "an error occurred... it may have already been uninstalled. With perfect disk it started the uninstall then "error 1719 windows installer service could not be accessed". Note i do not have system restore turned on
MSCONFIG seems to go to "selective boot up" automatically sometimes; i booted into normal mode but still get the issue and "normal mode" is still selected. I also tried safe mode but cannot open avast
I tried a repair install; it was a few seconds but that did not work; the first time it said repair operating system on D drive when it should be C; the second time it said C drive but said no problems were found.
I found a TEMP folder in C drive with note pads in there named the following:bcdinfo, bootfailure, disklayout, SrtTrail, SrtTrail
I am running windows 7, service pack 1, with Avast and zone alarm all updated. I am going to boot into another OS and full scan all the disks
1) So firstly were these false positives? Are there any portable sans i can run on the SSD OS? since i cannot load any of them when i boot
2) Secondarily how can i restore the files i put into the virus chest to see if that resolve my boot issue or any thing else?
3) How could this happen; i heard leaving your PC on over night is fine; i have anti virus and a firewall; as well as a router/hardware firewall. IS this just a coincidence that yesterday i left the PC on over night for the first time?
4) Also when/if i reformat how can i ensure the virus does not stay on the SSD; since i cannot write zeros to the drive or is it okay to do that due to security issue?
Pleas help Thanks
Pleas help Thanks
