- 22 Apr 2006
- Arms reach from mouse
K so i recently purchased a wideband receiver (which is great) and am looking a purchasing a 'Mag Mount' antenna for it, now for those of you who dont know about receiving transmissions the mag mount is a large magnet at the base of the antenna, for which there are two reasons: 1. to keep it on a car without it having to be permentantly attached and 2. a metal base is then used as a 'groundplane' which increases recieved signal strength.
Very nice you may say, but what the heck has it got to do with pc's? Well i want to put said magmount on my pc. ( pc on desk next to me, antenna on top leading to scanner beside it) And while the PC will no douobt make a great ground plate will the magnet harm my PC at all? It'll be far away enough from the HD im guessing ( we are not talking earth magnets here) but would be located right above the PSU... now as i have written this, im now thinking its not worth it
and probably wont be good.. anyone have any definate points to make on this?
Also handily i have the option to make a setting where the scanner will use a plugged in set of headphones as an antenna also, so would it be possible safely lead a wire to the ground pins on my mains supply(wall socket)? thus possibly acting as a HUGE antenna, not cut to wavelength sure but the size will make up for that. Thanks to anyone who can help, or those who can convince me i'm going to blow something up!
