New built PC (built on Saturday, been using the pc since but had the problem since then to)
System Spec:
CPU - QX6700
GFX - 8800GTX
RAM - Corsair XMS2 Dominator PC6400C4
Mobo - eVGA nForce 680i
When i turn on the PC for the first time i keep getting C1 error (which as far as im aware is memory isnt it?)
Well i can by-pass this by pressing the reset button on the case and it runs fine after that untill the next day when i go to turn it on (I only ever turn the pc on at about 2pm when i get in from work and its on untill i go to bed at 11/12)
Iv updated the motherboard driver but that hasnt seemed to work...
I have changed the RAM timings and volt to the spec it should be (from 5-5-5-18 to 4-4-412) and changed the CPU multiplayer from x7 to the norm x10... but still this problem comes about...
not a BIG problem but would be nice to not have to press the reset button when you turn on the pc
any ideas?
System Spec:
CPU - QX6700
GFX - 8800GTX
any ideas?
