Just put a new build together today, and for the first time ever I'm having POST problems
Three BIOS beeps. The first two are a lower pitch than the third, not sure if that's relevant or not.
Spec. as follows:
A few Google searches revealed that 3 beeps means RAM problems. To test this I tried each of the two RAM sticks in each of the two memory slots. Still got three beeps each time. Exact test results are:
Stick 1 Slot 1 - FAIL 3 beeps. Memtest86: Unexpected Interrupt - Halting CPU0 (after 1s)
Stick 1 Slot 2 - FAIL as above. Note that Memtest86 failed on exactly 27% progress through the first test each time
Stick 2 Slot 1 - FAIL 3 beeps (Memtest: lasts longer than last time, but freezes completely after 2s)
Stick 2 Slot 2 - FAIL as with first two tests
Any clues appreciated!
Thanks
EDIT: Just thought I'd add, I can enter the BIOS setup just fine and the "physical memory" value correctly shows as 4096MB. In the Hardware Monitor, DRAM voltage is reading at 1.5V.
UPDATE: I've tried running Memtest86 v3.5b instead of v4 and it's been running for over a minute now with no problems. Will update if it finds anything wrong.
UPDATE: Fixed, see post below
(Well, not fixed, it just wasn't broken!)
Spec. as follows:
- i5 2400 3.1GHz
- 4GB (2x2GB) Corsair DDR3 1333MHz RAM
- Corsair CX430 PSU
- MSI H67MA-E35 Motherboard
Thanks
See here for reference:
