27 Jul 2011 at 21:04 #1 Guru Guru Soldato Joined 8 Jun 2005 Posts 5,275 Hi all, Has anyone here had to post an entire PC before? Looking to sell mine and wondering how much postage to charge for a very heavy full tower PC? Would people risk posting one? Or is it likely to break in transit? Thanks, G
27 Jul 2011 at 21:06 #2 Captain Chaos Captain Chaos Associate Joined 17 Apr 2011 Posts 1,233 Location In front of my monitor check your covered by the courier. Id remove the CPU cooler if its a big lad as it may stress the mobo. Id guess at approx 20 quid depending on insurance.
27 Jul 2011 at 21:18 #3 dfarrall dfarrall Permabanned Joined 21 Nov 2010 Posts 2,315 Location Newton Aycliffe Depends on the weight, as long as its packed well and you remove the CPU cooler like said it should be fine.
27 Jul 2011 at 21:29 #4 Captain Chaos Captain Chaos Associate Joined 17 Apr 2011 Posts 1,233 Location In front of my monitor Ive posted base units and monitors before now without issue. Monitors are only covered with parcel force though!
27 Jul 2011 at 21:44 #5 Energize Energize Caporegime Joined 12 Mar 2004 Posts 29,962 Location England Just put it on the scales and go on parcelmonkey.
