- 6 Oct 2015
Afternoon All,
I currently have two laptops (office & gaming), which I am looking to pass on around Christmas time. As I no longer need to be as mobile I am thinking about going back to a desktop, but it has been about 10-15yrs since I last built one.
As you can imagine a lot has changed in that time and the more I read on everything from cases, motherboards, memory etc the more I get myself confused. I have tried putting something together but I am not sure if all the components are compatible. Or getting the better value for money.
It will be for both office & gaming. I play things like ESO, Skyrim, Thief and would like to get into the Assassin's Creed saga. I play on a 32" TV usually on high/mid (20-30fps).
My thoughts are:
Case: m-ITX or m-ATX, is on display in a white room so plan & simple. If windowed would like components to be aesthetically matching. Phantek seem nice & have a separate chamber for PSU. Or Corsair Carbide 240.
MB: no real idea I use to use an Abit NFSv2, MSI is what I know from the past, was never a fan of Gigabyte in the past.
PSU: Has enough power for everything with maybe 25% spare for expansion.
CPU: Either Skylake maybe 6600k or a 5th gen. Would like the build to last about 5yrs. £900-£1000 build or £200 a great.
CPU Cooler: I have read the Skylake is 91W so maybe a 140AIO. Quiet in office mode.
Memory: Not sure. Looking as some MB they say 3600 (of), so would go for 3600. But not sure if you can get 3400 and push to 3600.
GPU: I was thinking maybe GTX970, seems to be a mid ranged card.
GPU Cooler: GPU power is around 160W so maybe a 280AIO.
HD1: I already have a Samsung 840 Pro 120Gb, which I was thinking of using for OS.
HD2: I am thinking of maybe a 1Tb hybrid to use for game files and temporary data storage. I have separate external storage already for backup/duplication.
I am not sure about an optical drive. I think yes as I still have games on disk and backups. Although I have seen the move away from having one. Other peripherals I have already so is just the base unit and no OS needed.
As always I appreciate your help, feedback and advice.
Kind regards,
Andy.
My thoughts are:
Kind regards,
Andy.
