Potential Gaming PC Build
9 Jun 2020
Hi guys, any opinions on the following build to be used for esports titles like warzone/valorant would be appreciated:
PALIT GeForce GTX 1050 Ti 4GB STORMX Graphics Card
AMD Ryzen 3 3200G AM4 Processor with Radeon Vega 8 Graphics
Gigabyte B450M DS3H AM4 DDR4 mATX Motherboard
Gigabyte 120GB 2.5" SSD
Aerocool Cylon 700w 80+ Psu
EG Wider X1 Case
Corsair 4GB DDR4 2133MHz 1.20v DIMM Memory
Old 500GB HDD
Thanks all
Fred
Hello
I'd up your budget a bit to £500. That spec isn't at all good.
GFX card is previous Generation;
The CPU is an APU (Built in graphics, no need for them)
Board is OK if you don't plan on upgrading the CPU in the future
SSD OK for W10 only.
PSU = May eventually turn your PC into a very expensive firework. :p
Case = Think baked bean tin. (Apologies if you already own it) Id suggest an alternative.
Ram = too slow & not enough for W10 TBH.
HDD = depends on your storage needs, but you can never have enough storage.
£500 gets you:
My basket at Overclockers UK:
Total: £500.11 (includes shipping: £12.30)​
Apologies, it should be 2 x 4GB DDR4 and isn't 120GB SSD with 500GB HDD enough?
Cost is just over £400
Ahh OK 8gb is alright...
Well warzone is 96gb I think so that's most of the SSD gone... I find having a HDD is good for storing other bits like photos, information etc but have the majority of the games on a decent sized SSD for quicker load times and reliability
I appreciate there's a budget, but I think you'll regret buying a quad core and only 8GB of memory in 2020. That SSD will only be good for the OS, so you won't get any benefit out of load times in apps or games. It is just too small to use as a game drive.
If you can find the extra £100 - £150 or so, I'd really recommend it. An MSI Max motherboard would also have guaranteed upgrade to Ryzen 4000.
Nice one Joxeon. That looks a pretty sweet deal. I've just looked into the rx580 a bit (I'm a bit clueless coming from console, sorry) but the performance looks like just what I am after
