just wanted your thoughts please guys.
I have a 690 which works fine at stock settings but if I overclock it even a bit I get what can only be described as squiggles on the desktop every second or two before finally crashing and recovering.
I understand this probably means the GPU or memory is on its way out which is fine, I got given the card so no biggie.
before I get onto my question, here's a little background;
My computer is turned on @ 9am every morning and goes off @ about 1am every single day. I went away for 3 nights over the weekend so it was off for an extended period.
When I got back and switched it on, I got the squiggle things described above when the card went from 2D clocks to 3D on the desktop but no crashes.
I thought it might be heat related so I fired up Unigine Valley and let both GPU's sit at 99% for about 30 mins. After the burn in time no problems at all now.
My question is; firstly do you think its the GPU or memory or something else that might have cause this and secondly, do you reckon taking the GPU heatsink/fan off cleaning up and reapplying some paste might breathe a bit more life into the old dog?
I want her to last until the 880 is released and im a bit worried I might have to make an interim buy which I really don't want to do!
Much appreciated as always.
Mike
Mike
