Using this for a new loop i'm putting together, and in the process of leak testing i have encountered an issue with clouding after a matter of hours.
https://www.overclockers.co.uk/ek-water-blocks-ek-duraclear-tubing-16-10-clear-3m-wc-9dc-ek.html
Rig was left to run for 24hours to leak test and after that period the tubing was a terrible cloudy colour, so decided to test outside the loop to rule out and contaminants from the radiators etc.
Cut 3 small lengths of tubing and placed each one in ;
EK-CRYOFUEL CLEAR
MAYHEMS ULTRA PURE H2O
TAP WATER
After approx 24 hours, this is the result ;
all 3 samples had clouded.
To rule out that the exposed edges of the tubing caused it ( even though my leak test had clouded in normal useage ), i did a second test using a couple of fittings.
This is it after approx 18 hours - EK tubing with EK Cryo liquid
and here with a piece of unused EK tubing for comparison
Clearly ( pardon the pun ) an issue with the tubing in my opinion.
Anyone alse using this ?
EK-CRYOFUEL CLEAR
TAP WATER
