Potential ITX Case Suggestions
6 May 2004
Fareham
Hi guys,
Got a bit of a query around any recommendations with what to do with my case. I've currently got a Fractal Nano S ITX case which is housing:
i7 7700K
Asus Z270-I motherboard
GeForce 1080 Ti
Both CPU and GPU are watercooled with EK kit including two CoolStream SE 240 radiators. It all just about crams into the Nano S and it does the job.
However soon I'll have a Z370-I and i7 8086K shortly so while I'll have the thing in pieces, I'm wondering if there are any better case options out there. I move the thing around quite often hence the ITX case but I'm aware the Nano S isn't the smallest of ITX cases. Is there anything that might be better suited to this? Or should I just ditch the watercooling and go AIO/air and get a smaller case?
Had a SilverStone SG05 and now using a Raijintek Metis Plus, they're pretty small and can pack quite a hardware. With SG05 you're probably limited to AIO watercooling for CPU, for Metis, maybe both CPU and GPU if you plan ahead but it's going to tricky, it's fine if you're just doing it for CPU or GPU only.
Depending on your 1080 Ti model, might not fit in either cases though.
