- 11 Jan 2012
- Bedfordshire
May be a bit ambitious for my first attempt, but!
As my motherboard is on it's way out, I am looking at getting a new one. I love the look of the prodigy so I'm thinking about swapping to ITX and getting it. However, I've been beating around the bush about overclocking for quite some time now... Really wanted to do it last year but money restricted myself! I'm thinking about putting away about £100 in Feb and going for it in March.
Will the below work as a loop in the prodigy? Also, can you recommened the bits I have left out, please?
(I think its just the CPU block, GPU block and fittings. Lemme know if not!)
I'm going to swap from my green and black build to white/black so I'll just get some white pastel coolant I think.
Budget is around £450 (Obviously less is better if possible but!)
Should probably include I have an i5 2500k so 1155 socket on the CPU block and also a Gigabyte Windforce 3X 7950, so the best GPU that'll go with that please!
YOUR BASKET
1 x Gigabyte Z77N-WIFI Intel Z77 (Socket 1155) DDR3 Mini ITX Motherboard £98.99
1 x BitFenix Prodigy Mini-ITX Cube Case - Arctic White £57.98
1 x EK-BAY SINGLE RES CSQ - White Acetal £38.99
1 x EK DCP 2.2 Pump (12v) £29.99
2 x EK CoolStream Radiator XT 120 (120.1) £26.99 (£53.98)
1 x XSPC HighFlex Hose 1/2" ID, 3/4" OD, 19/12.7mm, 2m, Clear £4.80
Total : £298.82 (includes shipping : £11.75).
(I think its just the CPU block, GPU block and fittings. Lemme know if not!)I'm going to swap from my green and black build to white/black so I'll just get some white pastel coolant I think.
YOUR BASKET
