PotPlayer Media Player ( Recommended )- Thread
Caporegime
8 Sep 2006
On Ocuk
It works w/ madVR/HR/EVR and Reclock it's a much improved/faster version of KMP, including ffdshow
It supports seamless playback(up to 1000 -one thousand- AVI/WMV/MKV/MPG files at once, mixed containers are allowed), auto-resume on the last 200 opened files, has fully configurable XML skin files and also a D3D exclusive mode
Download this beta First
http://www.dvbsupport.net/download/index.php?act=view&id=230
Info and Update Thread
http://forum.doom9.org/showthread.php?t=148745
Latest Update for the Beta
Daum PotPlayer 1.5.30751 Beta Update 2011/12/06
- Fixed flickering problem of H.264 HD broadcasting
- Fixed deblocking problem of H.264 HD broadcasting
Download
I've heard very good things about this player, I did try it previously but had problems with certain .mkv files, I'm sure it's solved now though.
Would you recommend using the x86 or x64 version? Also do you have any recommended skins/icons? Seem's some of the ones in that thread are down.
(current user of KMPlayer)
I found the x86 version better something to do with newer updates :)
I'd recommend ditching KM and using potplayer now
Changes since v1.5.29996:
Updated built-in codec
Fixed position issue of ASS/SSA subtitles
Fixed an issue where the window has moved at the startup in certain environment
Some fixes while playing TS files
Added the ability to move the selected item via CTRL+Up/Down keys in the playlist
Fixed an issue that has no sound while playing certain MOV/MP4 files
Some fixes for ruby tag of subtitles
Fixed an issue that has no sound while playing avs (avisynth script) files
Fixed a bug that play time was incorrectly identified on some MP3/MOV files
Fixed an issue that opaque box option did not work with blu-ray subtitle
Added the ability to add time intervals to playback skipping
Changed default color space for some graphic cards
Added ASF embedded subtitle support
Fixed run-time error problem which occurred on some PCs
Added Apple ProRes Codec support
Fixed DivX H.264 decoder compatibility problem
Some fixes while playing more than two MP4 files
Fixed sync problem while playing H.264 files
Fixed flickering problem of VMR9 Renderless which occurred on some PCs
Improved video capture feature
