- 29 Oct 2002
Hi all,
On the back of a recent thread here, I obtained a number of TP Link TL-PA4010P units, to distrubute ethernet around the house, as I thought I had compatability issue with an older TL-PA2010P unit, it seems this is not the case.
The issue I have is that if I connect a unit downstairs, then run the ethernet to a TP-Link wifi extender, it completely shuts down the entire network, LAN and WiFI, so must be causing issue at the router level.
I'd assumed that you could set them up in this manner, using the powerline to send ethernet to the wifi extender however this is giving me massive grief, has anyone encountered similar issue?
To confirm, up and downstairs are on the same rail on teh distribution board, with a seperate MCB for up/downstairs, and other powerlines installed for the TV etc work ok, it only seems to be when I connect the WiFi extender to the LAN port that it all goes pear shaped.
Any ideas?
TA.
Any ideas?
TA.
