I am running seti units on my i5-2500k, and Milkyway is keeping the 7970 toasty. I also have one of those ocuk energenie monitors so i can see how many watts the pc draws.
edit: oh, note that the CPU is currently cruising at just 4.4GHz to save a little juice - 4.6 doesn't seem to give me a noticeable improvement.
Typically the system idles around 80-90 watts, and peaks at around 160w in normal usage.
Running the distributed computing on all four cores and the graphics card as above it pulls about 350w... not bad.
The weird thing is, if I set boinc to use 70 or 80% of the processor cores instead of 100%... the power usage actually increases to about 380w.
Wondered if anyone else had ever watched the watts and saw similar things, and if anyone knew why?
My guesses would be:
a) the 750W PSU is much more efficient when higher loads are drawn.
b) the cpu being maxed out limits how much the 7970 can do, becoming a bottle neck.
Any thoughts?
Any thoughts?
350w also sounds too low for an overclocked CPU and GPU. I think my 7970 system is using about 380w with the CPU idle. What is your Milkyway username so I can look at your task details?
