Hi guys,
I have recently upgraded my rig but I cannot seem to power up my computer using the power button, instead I have to flip the on/off PSU switch. Once it's up and running and I can do all of my general activities/gaming just fine. This was the same with my system prior to upgrade, though I needed an upgraded anywho!
The computer is fully powered at time of writing this. The power LED is actively flickering here and there, the reset button does it's job as does the power button when the machine is running so I don't think the F Panel connectors are the issue here.
Could it be an issue with my power supply? I ran everything through a calculator posted on another thread several days ago prior to ordering the parts and my current PSU seemed sufficient hence why I did not order another one.
My (new) rig:
NZXT H440 New 2015 Edition Case
Asus Z170 Pro Gaming Intel Z170 (Socket 1151) DDR4 ATX Motherboard
Intel Core i5-6600K 3.9GHz (Skylake) Socket LGA1151 Processor
TeamGroup Dark Pro 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit
Asus GeForce GTX 970 DirectCU II OC Strix 4096MB GDDR5 PCI-Express Graphics Card
Carried over parts from previous build:
2x Corsair SSD's @ RAID 0
1x mechanical 72000rpm Seagate 1TB HDD
Corsair AX670 PSU (I think it's 670 I know it's just north of 600w but <700, the NZXT PSU cover panel obstructs me from checking
Phanteks PH-TC14PE CPU Cooler
Asus Phoebus ROG 7.1 Sound Card
I'm pretty sure it's the power supply but posted wondering if anyone has had this before (though I guess chances of similar causes are somewhat neither here nor there!)
Thanks!
My (new) rig:
)Phanteks PH-TC14PE CPU Cooler
Thanks!
