Power cables - are they included with PSU?
28 Jun 2008
Hi
I have just received my components today including a Zalman ZM850 PSU.
It does not come with a power cable (i.e. to plug into the wall and supply electricity to the PSU). Should it? I have never heard mention of needing to buy the power cable separately.
It's a bit frustrating when the rest of my computer is now built and ready to roll!
Thanks for any help
John
Well, most will I would have thought...Most even come with both a european and UK one.
Might be worth looking on the box / 'manual' and see if it has a "What's in the box" section.
Tricky....
I found a list of contents now - it says "Power cable (not included in some countries)", so maybe that is it?
Probably something worth sticking on the FAQ - I wouldn't think to check whether a cable is included.
Thanks for your replies.
John
John
It is illegal to sell an electrical appliance in the UK without a plug fitted. Not sure if this is included in that, but would think so.
i think my kettle leads are breeding, always more than i remeber i had.
some have even got two heads so must be inter bred.
Bowza
Without a plug, is slightly different to a detachable, standard cable.
I'm not sure if it should come with one or not, it might be worth contacting the retailer and see what they say.
