Power Cables
29 Jul 2011
Near Northants / MK
Didn't know where to put this, mods if it needs moving you know what to do:D
I want to braid only the most visible cables as I'm going to be putting most of them at the back hidden, what extension cables shall I buy to braid?
24 pin ATX
8 pin (4+4) EPS 12v
PCI express power cables
They are basically the ones you can't tuck away and hide.
KiiYzOo;19819950 bitfenix do the nicest braided extensions :D[/QUOTE said:
+1 for the bitfenix range, the nzxt versions are a lot stiffer and have a very shiny plastic feel to them. Makes them a bit harder to bend into shape, unlike the fabric type bitfenix cables.
Bought a 8 Pin and a 24 Pin for £8.05, got the braid on order too just gotta buy the tool :D
Just hope I don't blow the motherboard.
