**** Power Colour Devil HDX 7.1 Sound Card****
7 Feb 2011
Stoke on Toast
Yes your eyes do not deceive you and and nor will your ears!!!!! ;) Powercolor are entering the Soundcard market with a reasonably priced competitor to the ROG phoebus.
PowerColor Devil HDX 7.1 Channel Soundcard @ £89.99 inc VAT
Introducing the PowerColor Devil HDX Soundcard, Using supreme quality components and excellent layout design to reach the top 124dB SNR, and offer crystal clear sound quality to audiophiles and gamers.
Key Features:-
- Up to 124dB vs 90dB (Average onboard audio)
- Wolfson WM8741 Hi-FI DAC
- Nichicon MUSE Audio Capacitors
- Separate power supply without causing interference
- Swappable op-amp sockets allows audiophiles to create own timbres and tonal combinations
- Built-in headphone amplifier supports up to 600 ohm headphone
- 7.1 channel daughter board provides true surround sound
Only £89.99 inc VAT.
ORDER NOW
Looks like theyve ripped off the phoebus software, wonder how asus feel about that.
Does look like a better alternate though assuming it sounds good, tempting to get one to compare to my phoebus on my 612 pros.... unless ocuk wish to donate one :D
The software is it's weakest point took me a good few minutes to even realise i had to right click on something to find the options. Also Xear is C-Medias own software so it's more likely that the pheobus software is a re-skinned a more visually pleasing version of this.
Sound wise it's a worthy challenger to the pheobus it probably creeps in on the STX IIRC. I can only compare it to onboard and the X7 on my desk from what I've heard it's upto the job.
agree with the review the daughter card could do with a a shield to match the main card and the cables could do with braiding but it does look good and the review was pretty decent.
