The end of the power cord, the bit that plugs into the laptop needs to be positioned in a certain way to pass power into the unit. I don't know if the power cord bit is at fault or whether theres something loose inside, how would I find this out?
But...if it's the power cord that's the problem then you're lucky. Do you have access to another cord you can try? That would narrow down the problem to your cord....otherwise you'll need a motherboard repair/replacement most likely...which isn't that great at all.
