Power Cut resetting the BIOS?
28 Jan 2011
hey guys,
I just happened to check my RAM speed in the task manager, and it was defaulted to 2133Mhz?
So I rebooted into the BIOS, and was greeted with a message that said the CMOS had been reset (cleared)?
I have had a couple of power cuts around 10-14 days ago (was not on PC at the times)..and the PC has been running fine, not noticed any performance issues (hence why I never checked the RAM speed before).
So, my question, can the power cuts cause this issue??? As everything seeems fine now, AND then, so im not sure??
Cheers.
Just turned off the PC to watch the last half hour of the World Cup Game, and now just fired up the PC and all settings are still active? So I dont think it can be the battery with issue?
Is the CMOS battery flat? When you say turned off, do you mean full off, at the mains?
Did you completely pull the plug or switch off at the wall? If not it would have kept power to the BIOS.
As someone else said, if you're over clocking and the pc crashes or detects an issue, it could reset the Bios settings as a precaution. Mine definitely does this and it's a pain!
For a couple of quid it might be worth replacing the cmos battery if it's over 4 years old or so.
in the meantime until i get a new battery, if it does lose power and resets the CMOS battery, and I go in to changing back my BIOS settings, that isnt going to damage or affect the board by any chance??
Also if someone can confirm the battery I need, that would be great, think I know, but wanna make sure!
No, for the board it's no different to turning the power off and overclockers might change the settings numerous times a day.
As suggested above, it was probably the automatic overclocking thingy that kicked in and did a reset because it thought you had unstable settings. It doesn't do anything if you power off yourself.
its gonna be a massive pain to remove this GPU, my CPU cooler is so big, it hampers the access to the GPU locking clip, and I worry about movement on the CPU cooler..
So I was thinking of keeping an eye on it, see how it goes before change? And like you said if it doesnt damage it, takes 45 seconds to configure the couple of BIOS settings, and it IS the battery, and its not often the power is interrupted (not like I get power cuts every day!), then leave as is??
Or if its defiantly recommended to change the battery, I will do it.
Yeah, I agree, I'd leave the battery and just keep an eye on it. If it keeps going, then you can look at your settings & the battery again.
cheers mate.
Its usually a CR2032 battery, that powers car remotes, watches. I've got one in my small digital scale. You can buy these almost anywhere that sells batteries.
awesome, will get them in case I change down the line.
Mine has a bios setting that resets cmos on power loss so maybe change that in your bios if you have it
will look at that mate thanks.
Does your mobo have a dual bios?
Might be switching over to second bios after power cut?maybe?
i dont think so dude, its "basicish" motherboard, im sure thats not on there.
well came, home, believe I had a minor power cut / trip as my internet lost connection for a few minutes, and when I came through to turn on the PC, the amp for my speakers was on (green) which happens when the power is restored. When I turn off it stays off (red).
And I checked Task Manager and my RAM etc is still at 3200Mhz, so the BIOS battery must be all good, quite possibly a BIOS reset as "precaution".
