- 30 Sep 2006
- Midlands, UK
Hi all,
so built a rig for a friend:
i5-9600k on a Asrock m-itx a/c
16gb ram
GTX1070
500gb m.2
1tb 850 pro ssd
600w leadtek fully modular
Case (now here's the thing...)
So, computer works fine (ish). But if turned off and back on display never works. There is no POST speaker to give any clues.
I have to power down remove plug, reinsert, turn back on.
This happened to me prior to handing it over, i swapped the ram out, but it made no difference.
Then i noticed that the 4-pin power molex (part of the main 20-pin connector) wasn't in correctly. So, after sorting that it seemed to work fine. Then after a day or so my friend reported the issue.
Now, this case, it has a gazillion rgb fans that are all connected to a little box controller and the case reset switch cable, instead of going to the front panel on the mobo, it connects into this controller. So each press of the reset button on top of the case simply cycles through the lighting scheme on the fans.
I've never built a case with a controller like this before so wondering if that might be the cause (guess i can find out by unplugging it). My case is similar but they all connect to the mobo or a power molex, yet still work in the same way wit the reset switch.
But the fact that unplugging, basically dissipating the power to get it to work kind of points towards the psu or possibly the mobo (not retaining capacitance or whatever?)
I dont really have any spare parts to test with, but what would be your checklist order please guys?
Thanks
16gb ram
GTX1070
500gb m.2
1tb 850 pro ssd
Thanks
