I've recently moved my whole computer into a new case, it has more room for fans and generally looks better. The old one was 6 years old.
The problem I'm having is that after hooking everything up seemingly fine I will press the power button, electricity will flow through the circuits lighting up things here and there and then it's of again. Mobo light remains on like HAL9000 staring up at my with an evil glare, but appart from that that's it. Done. No more.
I can hard power down and up again, then when the mobo light comes on I hit the power switch and exactly the same happens. This happens with different PSUs.
I may have the HDD LED, Power, Reset, BEEP and 2 other LEDs wired wrong, but I've tried multiple combinations and they seem to be in exactly the right place. The fact that it tries to fire up at all seems as to be proof that it's wired correctly. I don't think I've missed anything.
One HDD for now, has SATA + Power
PSU 500W Corsair (can look up the brand if you like, but the same problem happens with the old one which worked)
ASUS 4850HD with the plastic bit of the heatsink torn off.
2x2GiB DDR2 RAM, it should work fine, I've tried it in the yellow and the black positions.
Phenom II 940BE (moved back to stock cooler as the zalman needs to be tied between two galloping horses to detach from the mobo)
I'm at a loss, I'll keep at it and checking back. Hoping I don't have to buy a new MOBO, but if so are there AM3 mobos that work with my processor? If so a recommendation would be just gorgeous.
Thank you my darlings.
