- 4 Sep 2005
- Lowestoft
Basicly changed my motherboard in the last few weeks and only just noticed this new sound every now and then but im not sure if it is related to the motherboard or not.
Asus P5P41C
Thermaltake ultra 120 extreme + 120mm yates
C2D E6600
4GB Corsair DHX
ATI 4890
520w corsair PSU
2 120mm case fans
Basicly everyone knows the sounds a pc makes when its just switched off and everything looses power and winds down well every now and then the pc will make this noice but nothing happens to the pc, it will stay on no BSOD or freeze or anything. Ive had this happen when just surfing the web but not sure if its happened when gaming as i have headphones on but i get no issues when playing games either, been playing Mafia 2 and other latest titles with no issues.
When this has happened and ive heard it ive gone straight to the pc inside to check all fans are spinning as normal aswell as checking all temps on the pc and everything is the same as norrmal. Ive checked all fans inc psu fan and all are still spinning.
Does anyone know what i should do from here???? As this noise cannot be normal right? PSU is a few yrs old but cannot say its that as i have no proof, GFX card just over 1 yr old with warranty still but cannot 100% its that either. I see no signs when looking in the pc as to what it could be
Any help would be great
Thanks
Asus P5P41C
C2D E6600
4GB Corsair DHX
ATI 4890
520w corsair PSU
2 120mm case fans
Thanks
