Hi there,
So I'm moving house soon and I have a question in regards to how much computer stuff should I plug into an extension lead plugged into a UK mains socket.
My setup is as follows:
My Gaming PC (with a 850w PSU)
2x BENQ XL2411T Monitors (at 22W each)
Logitech Z906 Speakers (at a 500w max apparently)
All in all that adds up to a theoretical maximum of just under 1400w.
Is it ok to plug all of the above into a 4-way (surge protected) extension lead, which will be plugged into 1 UK mains socket?
I'm also considering the upgrade to a 1080 ti, and adding another 4k monitor into the setup, later on. Would that push it over the edge (if my current setup doesn't do that already)?
