Hey guys, Long time lurker first time post-er (Don't want to be confused with a paper based advertisement medium ;D)
I recently put together the following machine on a very tight budget,
AMD Athlon x4 640 3ghz
2gb Corsair valueram and 4gb Gskill something or other (had the 4gb stick from a previous pc)
Inno3D Gforce 8800gts 320mb (My budget for a graphics card was 40 quid and I got this off of ebay for 28..Good deal right?!)
ASRock 760GM-GS3 Motherboard
There's going to be two laptop sized hard disks in there and a single disk drive.
My question is this. I have around 22 pounds at the moment. What Will this power supply be adequate and if not anything else to recommend? http://www.overclockers.co.uk/showproduct.php?prodid=CA-238-CM
Oh I also just got the cheapest case I could find, some Asus case. It fits, that's all I care about
