Power Help
28 Jan 2009
Right Got my new system build in mind but i need help with the power
Spec
GA-880GM-USB3 MOBO
Amd Phenom II X2 Dual-Core (565) 3.4GHz Processor L2 Cache (2x515KB) Socket AM3 - Black Edition
Corsair Value 4096MB (1x4096MB) Memory Module 1333MHz PC3-10666 DDR3 DIMM 240pin CL 9-9-9-24
My question is what PSU should I get? What Wattage?
Cheers
No,
Never buy a case/PSU combination, of no brand....Antec maybe...but no don't do it unless you want to see a puff of smoke in the near future and some sparks....
Look at the Antec PSU again please. Or check out the OCZ's, Corsairs etc.
Cheers
Von
Why?
Even with a mid/high end GPU like a 6850 in there that system won't use more than 250-300w. The 430w Corsair will be more than enough.
The Antec would be better, only because it's modular though.
Because buying 1 PSU for upgrading in the future is always better than buying half a dozen ;)
No,
Cheers
Von
OcUK have done some great combo deals... good cases with good psu's, a combo is fine as long as you do your research on the psu.
