Power hungry system
Permabanned
8 Sep 2007
Glenfield, Leicester
hey guys
just out of intrest whar power supply would you recommend for this system?
intel q6600 (overclocked to 3.0ghz+)
northq siberian tiger cpu water cooler
4gb ocz ddr2 800 ram
evga 680 sli motherboard
2 x geforce gtx 260/280s
3 sata harddrives
would a corsair 620w do? or bump it up to 750+?
cheers simon
just to add, ive got a hiper 730w type R power supply at the mo in an old system, would this be alrite? or is it time ti upgrade :)
730 is fine
have you got the pc already btw?
if not i would not get 2xGTX 260 or GTX280 with that MB as you will loose a lot of performance due to the limited pcie slot speed
thxs for the reply, yep i have and picked up 2 gtx 260s cheap in the usa, got 2 for under $400 which weren't bad,
the motherboard ive had for a while, and processor etc.
will give it a go and see how it goes,
thxs for the reply simon
The 680i motherboard will be fine with sli gtx 260/280 as both pcie slots operate at 16x on this board. its only the 650 series that runs at 8x in sli.
corsair for me i think, 620w be fine? like the fact its a modular one so can keep the cables tidy :)
cheers
I have gone off corsair because the rma shipping address is holland so if it goes wrong even 1 day over 12 months you are looking at £30 + to rma it.
Try and buy a power supply with a uk shipping rma depot I hear tagan doesn't charge to rma a power supply.
