- 14 Oct 2020
Hello guys,
I'm experiencing some problems with my Gainward Phoenix RTX 3080(i've heard that Gainward is the same company that Pallit. Is that true ?).
First of all, the VGA is a BEAST and i'm trully happy with the magnificent performance over the games (COD WARZONE, CS GO etc.)
But im thinking that i'm not using all potencial of the card. With the stock clock no tweaks, im getting POWER LIMIT AT 320 W, after i get power limit, the clocks reduces, and gets around 1800-1830 mhz, even that the msi afterburn curve goes to 1995 mhz.
I'll explaine to you:
This is my stock config:
As you see in the picture above the turbo boost should go to 1995 mhz with 1125mv. But this doe's not happen. I got Power Limit way before.
So, when im benchmarking my clocks stay bellow 1800 Mhz like this picture bellow: And it should be above 1900 Mhz.
So, im not using the full potencial of the VGA because im allways running at 1800-1820 mhz limited by my 320 W TDP.
Im 3dmark Time Spy Graphics i got 17600 (STOCK) and i managed to undervolt and get 17900 with 868mv@1830(With this config i dont have problems with the power limit. This is the max voltage and core that i get stressing the VGA before get power limit problems.
In games i managed to undervolt 925@1920 mhz, so i can play without power limit all my games and get this constante 1920 clock. This is my config for day use.
That is all. Is this real problem ? A new BIOS should correct this ? My 3dmark time spy score seens fine compare to other cards. I already update my bios with the latest one(30/09/2020).
Thanks in advance and im really sorry about my poor english.
