Power Limit
20 Sep 2014
Hi,
I have to set 50%power limit(using afterburner) to my gpu, otherwise i will have artifacts or CTD when gaming.
Does it mean my gpu is dying?
Titan XP
I7 9700k
16gb
650W Titanium Seasonic
If you have to lower it that far, it probably is dead but i would check to see if the psu isn't the culprit first. Have you tried your gpu in a different rig or tried a different psu?
Have you checked that the heatsink on it is not clogged up with dust ?
Also have you checked what temperature it heats up to ?
