- 18 Dec 2023
- Gloucestershire
Hello
Looking for some help. I have previously used Vodafone broadband (and the Vodafone router) with two power line adaptors between my home and my wired shed in the garden. Has worked perfectly for two years - no flaws.
Moved to YouFibre and they supplied an Arris router. When I plug the adaptor into the LAN, it's fine for 3 minutes...single gets to the shed, all fine....and then the router reboots itself...it completes reboot...then reboots again.
All the plugs are in wall sockets. When I plug the adaptors back into the old Vodafone line (I still have this running as I anticipated problems) it works normal. I have changed the Lan wire, I've swapped the power lines around. Fine. Have plugged a laptop into the LAN port and it's fine also.
Any ideas what might be happening? Would really appreciate anyone's help!
Kit
Arris NVG578LX router
Devolo Magic 2 Power line Adapators
Kit
